Network Rendering - Stops When Manager Sleeps
I continue to experience issues with Network Rendering overnight.
I have my MacBook Pro set up as the manager, and the Rendering Machine is a PC. As long as the MacBook Pro is awake, all is well. But when I leave things running (apparently not, though) overnight, the job stops until I wake the MacBook Pro in the morning. Note current job now clocked at 14+ hours. Sigh.
I’ve done everything I know to prevent the Mac from pausing the Network connection, but I am missing something.
Here are my sleep settings from the Terminal. Note Keyshot Network Rendering SHOULD be keeping the MacBook Pro awake…
Looking at this terminal output, I believe some settings are contradictory to the power management settings I shared above. I’ll look into this. In the meantime…
Has anyone experienced this, and can you share best practices here?
Hi @dan.spore! That’s frustrating, sorry that you’re experiencing this.
First, there was a thread in our old forum about this. Note it’s from about six years ago, so I’m unsure how relevant it might be today: Settings for avoiding a mac falling into sleep mode
I also asked around internally - one suggestion for you to try:
Your Mac is currently prevented from sleeping by KeyShot and caffeinate.
  • If renders are still failing or pausing, it’s likely a display sleep → GPU issue on M-series chips or a battery mode override.
  • Use caffeinate -i -w $(pgrep -f KeyShot) during renders to bulletproof the session.
I’ll let you know if I hear anything else. Someone else might have some good advice for you as well.
@maura.frost You’re on it! :smiley:
@dan.spore Your terminal settings appear correct. Below is an addon to Maura’s post.
Prevent Your Mac from Sleeping While Rendering in KeyShot
If you’re rendering on macOS and your system keeps falling asleep, here’s a simple way to stop that using a small script.
Step-by-Step Instructions
  1. Create the Script
Open TextEdit, set it to plain text (Format > Make Plain Text), and paste this:
#!/bin/bash
echo "Preventing sleep while KeyShot is running..."
echo "Done. KeyShot has closed or finished rendering."
  1. Save the File
  • Go to File > Save
  • Name it KeepAwakeDuringKeyShot.command
  • Uncheck “If no extension is provided, use .txt”
  • Save it to your Desktop
  1. Make It Executable
Open Terminal and run:
chmod +x ~/Desktop/KeepAwakeDuringKeyShot.command
You can now double-click the script any time before starting a render. It will keep the Mac awake until KeyShot closes.
Optional: Advanced Version
This version watches for KeyShot and KeyShot Network Manager processes:
#!/bin/bash
echo "Monitoring KeyShot processes to prevent system sleep..."
pids=$(pgrep -f "KeyShot|keyshot_network_manager")
if [ -z "$pids" ]; then
  echo "No KeyShot-related process found. Exiting."
  exit 1
fi
caffeinate -i -w $pids
echo "KeyShot processes have exited. Sleep is now allowed."
Save this with the same steps above.
Bonus: Testing Without KeyShot
You can test the script behavior like this:
#!/bin/bash
echo "Staying awake for 10 minutes..."
caffeinate -i -t 600
echo "Done. Sleep allowed now."
If these do not resolve your issue, please submit a ticket to the customer portal.
KeyShot Support
Thank you, @don.tuttle and @maura.frost! I appreciate both of your replies and I will give these suggestions a try.
@don.tuttle - especially keen to try these scripts on overnight jobs.
Thanks again!
